Michaels Web Site
Sonex Standard Gear
L01
Grind brake cams
Note: everything here is something I got from another builder's web page. Thanks!
- To spread the brake shoes I bought the old style wood clamps, cut notches at the OUTSIDE faces, and UN-screwed the clamp to spread the shoes apart.
- Removed the rotating cam that makes the shoes spread out when the brakes are actuated.
Other builders have noted that the sharp edges don't let the brakes work properly and fully, so rounding off the sharp corners appears to fix that.
- So I got in there with my Scotch Brite wheel and ground off the corners as in photo #3.
- After putting the cams back in place, they did seem to work very smoothly.
NO MORE BUILDING FOR A COUPLE OF WEEKS. I will be at Airventure Oshkosh 2012 for several days, then off on vacation for the rest of the time!
Using wood clamps in reverse, to spread the shoes.
Brake cam as delivered.
Brake cam with corners ground off.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
