Michaels Web Site
Sonex Standard Gear
C01
Elevator trim
Finished the elevator trim system.
- Riveted the trip handle support bracket.
- Installed the wire housing (black, in photo #1).
- Made the Z bend in the trim tab end of the wire, and installed it in the trim tab (photo #2).
- Tightened down the screw on the swivel bolt and cut off the extra wire (photo #3).
Trim and flap notch assembly riveted in place.
Wire to trim tab installed.
The trim wire in place. I left extra wire just in case I need some more adjustment.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
