Michaels Web Site
Date: 4-23-2012
Number of Hours: 3.00
Manual Reference: D02/D01
Brief Description: Begin install of windscreen
I got the windscreen and windscreen bow materials today from Sonex.
- Test fit the bow. The elongated holes in the upper stringers were a bit too small, and a bit too far forward.
- So I spent some quality time with my files, widening and elongating the holes.
- Then I marked the center line of the canopy, front to rear (photo #1). That way I could see how the center line of the bow (which I also marked) and the windscreen were lining up.
- I used a wood 2x4 and a rubber mallet to bend over the upper flanges of the forward firewall (it holds the fasteners for the windscreen). The fuselage stringer acts like a bending brake, giving a nice straight bend.
- Test fit the windscreen (photo #2). No dice. The bow was up too high.
- So I cut 3/4" off each end of the bow.
- Test fit the windscreen. Still no dice. The bow was still a bit too high.
- I cut off another 1/4" from each end, then test fit the windscreen again. Now it fit, at least at the aft end. At the forward end (photo #3) you can see I will need to trim the material at the forward end of the wind screen, until it lies flat on the firewall.
- Through the holes in the side of the fuselage, I used a Sharpie to mark where the holes needed to go in the bow (to fasten it to the fuselage).
- Took the bow out, then pilot drilled 1/16" holes where I had marked the bows. Then updrilled to 3/32" (they will need to be bigger, eventually).
- Put the bow back in the fuselage and held it in place with long reach clecos (see photos on next page).
HIT 1,600 HOURS ON THE PROJECT, TONIGHT.
Drew a centerline (it's on the protective plastic) at the front and rear
Test fit the bow and canopy several times. Trimmed bow as required.
Once the back was set, the front showed how some material needs to be cut.
