Michaels Web Site
Sonex Standard Gear
n/a
Install accessory outlets
Installed the two accessory electrical outlets (lighter plugs!).
- Cut the glare shield fabric at the two holes (left one seen in photo #1).
- Soldered the wire, and added shrink tubing, to the two accessory outlets.
- Installed the accessory outlets in the glare shield (photos #2 and #3).
Holes cut in fabric for accessory outlet.
Accessory outlet installed. Note cap that is part of marine-grade outlet.
Outlet seen from under the glare shield.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
