Michaels Web Site
Sonex Standard Gear
C01
Left rudder cable
Installed the left rudder cable to the rudder pedal.
- Used a 3/8" drill bit to set the 3/8" distance off the firewall (photo #1).
- Marked the location of the clevis hole on the aluminum rudder link.
- Removed the link, drilled the hole and deburred, then cut and rounded the end of the link.
- Installed with bolts and cotter pins per plans.
- Attached the rudder return spring.
Used a 3/8" drill bit to set the 3/8" off the firewall.
Rudder cable and return spring fully installed.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
