Michaels Web Site
Sonex Standard Gear
F12
RIGHT forward fuselage
Continued installing the multitude of parts and pieces, including lots of gussets. Then updrilled everything to size per the instructions.
Tomorrow I will need to uncleco, install/drill some pieces that have to be done from that side, and then I can debur everything.
There are a damn lot of rivets in an aluminum aircraft!!!
The forward end, prior to updrilling
The aft end, prior to updrilling
Not that you can tell, but this is the whole panel AFTER updrilling
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
