Michaels Web Site
Sonex Standard Gear
AFT FUSELAGE construction
- Finished aligning, drilling and cleco'ing the upper longeron
- Aligned, drilled and cleco'd the lower longeron
Upper longeron cleco'd. Lower longeron in place for drilling.
Lower longeron in place with double sided tape + duct tape
Top and bottom longerons drilled and cleco'd
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
