Michaels Web Site
Sonex Standard Gear
LEFT flap construction
- Laid out the angled cuts at the inboard/root end of the flap skin
- Made the cuts at the angles with the Dremel cut-off wheel
- Made the rest of the cuts with the shears
- Laid out and drilled all the pilot holes in the skin, for the rib attachment
- Marked all the rib flanges with a centerline
- Drilled and cleco'd one face of all the ribs (photos 1 & 2)
Outboard end
Inboard end
Typical pilot holes in skin
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
