Michaels Web Site
Sonex Standard Gear
LEFT aileron construction
- Got the last rib located and pilot drilled, then updrilled all the holes.
- Pre-drilled small pilot holes in the hinge, set the hinge as I did for the right aileron, then
- Started drilling the hinge into the aileron. Got a half dozen holes set.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
