Michaels Web Site
Sonex Standard Gear
Landing light lens install
Per the previous log page, here is the "bottom" mounting bracket assembled with the 3 nut plates installed, and finally with the lens installed.
I still need to get flush screws to replace these temporary ones, and I need to install the foam tape that came with the kit.
The "bottom" mounting bracket with the 3 nut plates.
The installed lens. The screws sticking up are temporary until I get flush screws.
Another view of the "bottom" of the lens assembly.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
