Michaels Web Site
Sonex Standard Gear
RIGHT wing root doubler + riveting
- Finished dimpling and updrilling the root doubler and the associated wing skins/ribs.
- Riveted along the entire length of the top spar cap.
- Installed all flush rivets in the top surface of the leading edge skin, and about a dozen standard rivets at the upper aft skin.
Dimpled areas at root.
Length of spar + top surface of leading edge skin with all flush rivets installed.
Typical flush rivets.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
