Michaels Web Site
Sonex Standard Gear
RIGHT wing preparations for riveting
Started back up on the RIGHT wing.
- Deburred the holes on an aft skin along the rear spar
- Enlarged the hole in the lower aft wing skin, and set the tie-down bolt in place and torqued the nut.
- Installed nut plates for the installation of the pitot assembly.
Reached 1,100 hours tonight.
Tie-down bolt in place.
Pitot assembly ready for mounting.
Nut plates in place for the pitot assembly.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
