Michaels Web Site
Sonex Standard Gear
RIGHT wing - deburring
Finally got everything deburred. Then I located (lower aft wing skin) and drilled for the wing tie-down bolt.
Started puting the wing back together with clecos so I can install the fiberglass wing tips when they arrive, and then finally start riveting.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
