Michaels Web Site
Sonex Standard Gear
Dimpling RIGHT leading edge skin
- Finished dimpling the top surface of the leading edge skin
- The dimpled all the remaining nose rib holes
Next I need to finish dimpling the lower surface of the leading edge skin.
Dimpled leading edge wing skin
Using the simple dimple die with a hand rivet puller, to dimple the ribs
A dimpled rib
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
