Michaels Web Site
Sonex Standard Gear
RIGHT wing deburring + nose skin
Not much work over the past week. Was on vacation for half of last week, then got sick after returning. Just got back to work today.
- Finished deburring/sanding holes in ribs and lower aft skin
- Used one leading edge (nose) wing skin as a pattern to lay out the second
- Cut out that second skin
- Also went back to the LEFT wing and installed a third wire for the future wing tip lights, and set the 25 deg angle of the aileron bellcrank.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
