Michaels Web Site
Sonex Standard Gear
Left Wing - Add rear spar + make root ribs
- Pilot drilled all the ribs at the interface with the rear spar.
- Then updrilled and cleco'd.
- Leveled the wing in preparation for installing the root ribs.
- Modified the root ribs per the plans (deburring and adding gussets will be tomorrow).
Rear spar updrilled and cleco'd in place.
Leveling the wing in prep for installing the root ribs.
Modifying the two root ribs per the plans.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
