Michaels Web Site
Sonex Standard Gear
FINISHED the elevators!
- Deburred the elevator hinges
- Cleco'd the hinges in place
- Riveted the hinges and the leading edges (to the ribs)
I put the hinge pins in to make sure everything fit, and moves freely. Thankfully it all does! Whew!
To finish sheet T02 I need to install the trim tab. I'll do that this weekend.
Upper surfaces...
Bottom surfaces...
Hinge gap
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
