Michaels Web Site
Sonex Standard Gear
Elevator hinges
OK, I guess I wasn't quite done with T07. I needed to drill the holes in the hinge halves to be truly done.
So tonight I aligned the elevator assembly with the horizontal stab and marked the elevators for the hinge locations.
Then I marked the hing hole locations and drilled on the drill press. Deburred, then cleaned the layout marks off the hinges.
Marking elevator hing halves for drilling
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
