Michaels Web Site
Sonex Standard Gear
Cut rib blanks and drilled for template/jig
Cut out the remainder of the 20 main rib blanks from this .025 sheet, then drilled the two alignment holes in each, so they can be stacked between the rib template/jig.
A stack of 20 main rib blanks.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
