Michaels Web Site
Sonex Standard Gear
Bent spar W12-02R & Finished W12-02L
- Bent the second rear wing spar, W12-02R (again, all as one piece)
- Finished drilling and deburring all the holes in W12-02L
Roughed out hole in W12-02L (used drill press to make many holes)
The same hole, all cleaned up, with all the pilot holes drilled as well
W12-02L done
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
