Michaels Web Site
Sonex Standard Gear
Bent 3 fuselage channels
Bent 3 fuselage channels:
- F23-10
- C06-04
- F07-05: this was a tough piece. One leg had to bend 30 deg past 90 deg, which necessitated some shims on the bending brake to get there. Then the other flange was so narrow that it kept slipping out of the brake. I should have bent this first.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
