MICHAEL'S WEB SITE
Date:  1-12-2021
Number of Hours:  1.00
Brief Description:  Leak test
Sealed up the tank and pressurized to inflate the ballon. Let it se for 2 days while monitoring the size of the ballon. (I use a cloth tape measure to check the curcumference.) As before, the only change is size was due to temperature change in the shop.
Next, i carefully checked for any leaks with soap and water at all rivets, joints, and fittings.
I have found "Bubble Soap" from the toy deptment to work best. All checks good.
No Leaks!
Testing with soap and water
