Measured and made sure the positioning was correct. Then, drilled the forward spar mounts. Made the shins and installed. Lastly, set the height of the rear spar to 11/32" and drilled the spar to rear mount bolts. Confirmed 0 deg incidence by measureing the tooling hole to aft deck distance as per plans. Perfectly even!
