Picked up the electric boost pump for the fuel injected engine the other day. Primered a batch of parts and begane the installation. Modified the F-982-C center cabin cover for the new fuel pumb mounting brackes. riveted the pump cover together and installed all the nut plates. Mounted the pump and bent fuel lines from the valve to filter, and filter to pump inlet.
