Begain the Flap control installation. Installed the F-661-ef bearing blocks onto the ends of the Flap actuator weldment and installed into place behind the 705 bulkhead. Pre-drilled and cut the "center", F-680 bearing block in half. Installed and bolted then all into place. There is a fair amount of "drag" inoperating the weldment up and down. I read several other builders logs that had the same comment, so i'll not worry about it for now.
Drilled and safety wired the lwer rod end connection as per the drawings.
Fabricated and assembled mounting parts into the F-766A flap actuator channel.
