Installed the bagage compartment bulkhead. Pretty straight forward. Trimmed the top panel and layed out all the attachment holes. Clamped in place and match drilled the F-706 bulkhead for nutplates, Riveted all the nut plate in place. Added the plastic wear pads to the upper and lower panels for the sholder harness cables, then screwed the panels in place.
Don't forget to run a tap through the lowest attachment nutplates along the floor, or you will have a tough time getting the screws in.
