Time for something a little different. Cut the brake pedal mounting angles brakets from the supplied aluminum angle and riveted the pedals together. I am installing the "Optional" brakes on the passenger side, So... 4 pedals in total.
Assembled the pedals and master cylinders to the rudder padal assembly and hung it into position inside the forward section.
I have to say... Working with the airplane upside down makes it challenging to keep the "Lefts and Rights".... "Up's and downs" straight in my mind and when marking parts.
Drilled the mounting holes for the pedal assembly with 3 different positions for adustment later on.
