Next up was fitting the F-970 side skins in place. Started off by cutting the 1 1/2" hole for the step mounting. Then, installing and cleco to the underlying bulkheads. Again, and little bit of "up and down" adjustments to the height and angle of the tailcone was needed to get perfect alinement of all the rivet holes where the center section and tailcone come together.
