Began working on the wing tips. Installed the Aileron and used the alinement tool to find and block it into the "neutral" position. Next, i trimmed the tip for clearance of the aileron and mounted as per the drawings. Installed the tip and alined it with the Aileron and drilled and clecoe'd into place. Rmoved the tip and drilled the W-914 rib in the proper position.
