Temporarily installed the R. wing Aileron and adjusted the control rod for "Neutral Position" using the alinement tool. Then, i did the final adjustment on the Auto Pilot Roll servo linkage and torqued all the fasteners to spec.I also installed the "Limiting Bracket" on the servo arm to prevent overtravel. I also crimped all the D-Sub connector pins to the servo wire harness to make life easier once the wing is closed.
