Finished riveting the inboard skin, (L. wing) And ran the Pitot tubing Throught the ribs and snap bushings. Cut and flared the aluminum tubing on the Dynon Pitot tube and torqued the fittings in place. I fabricated a mounting bracket that mounts to the bottom side of the pitot mast to support the tubing just up from the AN fittings. I used 1/4" wire loom to protect the tubing from wear. A simple "Zip Tie" mount was used at the support bracket that can be easily cut to allow the pitot to be removed should the need ever arise.
