MICHAEL'S WEB SITE
RV-9A
Control rod construction
Cut the control rods to lenght as per plans. De-burred and primered. I used corks to plug the tubes and poured some primer inside. Then rolled them around to coat the inside fully. Drilled and riveted the threaded ends in place.
Aileron control rods
Plugged ends to primer inside.
Threaded ends installed.
RV-9A Home
1243
282
Fuel Tank Assembly
363
Service Bulletins
Tech Support
462
