Began L. side flap final assembly. Riveted the nose ribs and main ribs to the spar. Cleco'd the top skin and nose skins on and riveted in place. Then, installed the bottom skin and used my "Bucking bar on a stick" to rivet the lower skin to spar rivets. Works great. I did the same on the aileron spar rivets also.
spar and ribs riveted.
using rathet straps to roll the nose skins into place
