Turned the page on the instructions and started work on the L. side flap. Cleco'd the nose ribs, spacers, and hinge brackets together and installed onto the spar. Fabricated the FL-906-A (Attach Angle), And FL-906-C (Spacer) from hstock material provided in the kit. Installed and match drilled at the Root end of the spar,
