Finished Prep work on the HS tips for now. They will still need a little final filling and sanding before permently installing. But it's easier to store with them off. Also got the rudder tip trimmed, drilled and countersunk. Removed the protective vinyl and wrapped the HS in plastic. Hung it from the shop cieling to make room for the wing kit.
