Brief Description: Connected Throttle and Choke cable to Carbs
50-05 to -07: Connected the throttle and choke cables to the carburetors. Had some difficulty to get the left and right throttle cables to be synchronized with the throttle arm movement. Trimmed the cable leads per the plans and placed heat shrink tubing to the ends.
42D-20: Inserted the RZ944 wire (from pin 12 of the old AP backshell) into position 28 (Audio Ground) of the EFIS D-sub. The new AP D-sub that came with the SV-AP KNOB harness has position 12 already occupied. Uninstalled all the D-sub connectors above the Panel Base and sprayed DeOxit Gold to the terminals.
