Brief Description: Adjusted idle speed and engine run up
Brought the aircraft out of the hangar and fueled it. Turned the idle speed adjustment screw 1/4 turn clockwise and then started the engine and let it warm up.
PAP G6-1: Run up the engine to 4000 RPM and checked the Canopy Latch warning (audio and visual) and both work. Reduced the RPM to 3000 and there was no audio warning with the canopy unlatched. Reduced the throttle to idle and was getting 1700 RPM. Made small CCW adjustment to the idle speed screw to lower the RPM a little bit more but I'll fine tune at another time.
