Brief Description: Repaired a Trim wire, Check Comm radio
31B-04: Removed the pin in position 22 of the Tunnel harness connector. The pin was connected to the WHT/BLU wire from the P-30 Trim harness which I found disconnected 2 days ago. Crimped a Molex pin on the WHT/BLU wire and inserted in position 22. Tugged on each wire to ensure all are properly seated. Sprayed DeOxit Gold on the pins and joined the 2 Tunnel connectors. The AST moves up and down when the Trim switch is activated.
PAP G1-1: Checked the GTR 200 radio again and played with the settings. The sound when the Monitor switch is off is again weak at 100% volume. At times it is intermittent. When the radio is first turned ON the volume sounds "normal" momentarily but then gets weak again. I'll have to recheck the wires and settings again.
