Pulled the F339 and F340 Aux Music Input (Right and Left) pins from the WH-00036 backshell connector. Left the connection to the wire shield that connects to Pin 26 (Ground and other wires). Then tested the new Aux Music Jack. There was no sound initially but after playing with the settings in the GTR 200 I could hear the music playing from the Ipod. The sound was good for the most part except there are gaps in the sound.
Disconnected the F64 and F65 pins from the Tunnel backshell connector (Pins 1 and 20, respectively). Also disconnected the green wire from Pin 7 (Ground). While working on the wires I noticed the WHT/BLU wire from the P30 Pitch Trim harness was not connected. I must have pulled it from its pin while working on the other wires. I'll verify where it goes and crimp a new pin and re-insert it in its slot. Put heat shrink tubing on the exposed pins at the Fuselage backshell connetor, folded the wires and tie wrapped on the harness.
