Brief Description: Worked on ADAHRS and Autopilot wiring
Inserted the wires and pins for the ADAHRS into the 9-Pin D-Sub connector. Inserted the wires (and Molex pins) coming from the Autopilot Disconnect Switch into a Molex plug. Attached the F-00023 SV Center Panel to the Panel Base and the Instrument Stack Angles. Inserted wires from the Autopilot Harness (WH-00025) into a Molex receptacle and then joined the 2 Molex housings. I'm still stumped with the 2 autopilot harnesses I have and which one is supposed to connect to the AV-5000A Module. I'll need to contact Van's about this.
SB 13-04-05: Riveted the F-1201G-MOD Rib to the oil tank side brackets to complete this service bulletin.
