Removed the main wheel fairings from the brackets. Final drilled #19 the holes for the brackets. Final-drilled #27 3 holes in the left wheel fairing and riveted 3 nutplates at the hole locations. Put together the two left wheel fairings and final-drilled #27 the remaining holes. Drilled nutplate rivet attach holes in the U-00001B Aft Fairing and countersunk them. Riveted nutplates on the #27 holes.
