Final-drilled the #30 holes to #19 in the front and aft wheel fairings and roughened the areas around the holes on the inside of the fairings. Applied epoxy flox mixture around the screw holes on the inside of the fairings. Installed both front and aft fairings on the brackets.
Also trimmed the outboard edges of both of the fairings and will need to do more trimming later.
