Bolted the U-00002 Wheel Fairing Brackets and the U-00004 Bracket Mounts to the axles. Applied Loctite to the threads of the AN3-40A bolts. Torqued the bolts to 30 in-lbs. Temporarily installed the U-00001B and U-00001A (Aft and Front) Fairings to mark the trim lines and then trimmed the fairings on the right side.
