Brief Description: Installed right wheel and fairing bracket
Installed the U-00003 Bracket Mount to the right main landing gear and then installed the right wheel and brake assemblies. Torqued the bolts to 100 in-lbs. Installed a U-00003 Wheel Fairing Bracket to the U-00003 Bracket Mount and torqued the bolts to 30 in-lbs. Applied Loctite to the threads of the AN3-4A prior to installation.
