Installed the U-00005A Wheel Fairing Front and U-00005B Wheel Fairing Aft on the WD-01230-1 Nose Fork. Checked the clearance from the nose gear assembly and the tire. Trimmed the fairings to have the minimum clearance to the nose gear assembly and the tire. Enlarged the bottom right screw hole on the U-00005B to line it up properly to the U-00005A nutplate screw hole.
