Brief Description: Worked on left wheel assemby and brake.
35-02, 35-04 and Matco Manual: Removed the left wheel so I could access the nuts outboard of the brake plate. Tightened 2 of the AN4-16A attaching the Brake Plate and Axle to the left Main Gear Leg. Torqued the nuts to 100 in-lbs. Greased the bearings with Aeroshell 22 and installed the left wheel and the brake shoe. Place a new cotter pin to secure the axle nut.
