Applied stripper gel on the cured epoxy on the sides of the fuselage. It worked but required several applications and scraping. There are some stains on the fuselage skins which have remained even after cleaning with acetone and epoxy stripper.
Remove a row of vinyl cover from each wing and cleaned the surfaces with acetone. I’m still waiting for the local avionics technician at the airport to look at my radio. After it is fixed I can installed the skin above the panel and then the Canopy.
