Brief Description: Installed placards and cleaned the skins
Installed the “N” number placard on the F-00028 Instrument Panel Left above the Master and Ignition switches. Cleaned the sticky residue and dirt from the Tailcone and Flaperons. The residue on the left Flaperon does not come off easily with acetone and I’ll need to use something that works better. Installed the “N” number stickers on the sides of the Tailcone.
Removed the protective lining from the inside surface of the Aft Window. I was not thinking when I installed the Aft Window and did not remove it first. I loosened some of the screws attaching the window to the Roll Bar and used wood tongue depressors to push the part of the lining that is between the window and the F-1232A Roll Bar Brace.
