Brief Description: Worked on wiiring in L Fuselage, installed Nav lig
40-11: Originally planned to replace the ES-000103 Strobe Noise Filter but decided to keep it since it still looks OK. Wrapped self-fusing silicone tape around the wires and the insulation that I had cut to inspect the noise filter. Placed tie-wraps in several places to keep the wires and noise filter together.
31B-24 and 40-10 to -11: Installed the left F-00034 Wing Electrical Bracket to the seat ramp and then placed the F-00032 left Fuselage Side Cover. Reconnected the LN-200 Wing Tip Nav/Position/Strobe lights to the Molex connector housings and then installed the lights on the W-1222 Extensions.
11-09: Installed the VS-1204 Fwd Skin on the front of the Vertical Stabilizer.
