Brief Description: Check for short in Strobe Power wiring
Re-installed the AV-50000A Control Module to check if the short is still present in the Nav/Strobe fuse slot in the Power and Swtich Module. When I checked pin 1 in the Switches receptacle in the Control Module I did not find continuity. Tested the fuse slot and the upper terminal in the fuse slot is now showing continuity. Previously it was the bottom terminal with continuity. This may just reflect the pin swap that I did and not necessarily correcting the short in the circuit.
